How to draw this isosceles trapezoid with these rounder edges on sides and top.
How to measure the dimensions of the top with the intention to draw it same size.
I wish to know how to draw it using native tools instead of using Fredo6 RoundCorner extension or FredoScale, of course I did several tries with follow me, push/pull and intersecting options with no success before writing this post.
There are a couple of reasons why I want to do it with native tools.
Even if an extension can do it, I want to know how the manual way to do it.
I’m working in something I’d like to show with native tools.
SImply put, this is not something that I would generally do without RoundCorner. While it CAN be done, the whole point of extensions is that what will take many steps manually can be done in a single step.
Having said all of that, I would draw the initial shape, then, whole still in 2d, add the arcs to the top two corners. Then P/P into 3d and use follow me to pull arcs around the sides. After that you will likely need to do a little clean up.
Thank you @john_drivenupthewall
I agree with the use of the extensions, I use RoundCorner from time to time, but I also like to understand what it’s doing for me.
I’m considering the possibility of making a tutorial about how to draw a model I found in the 3D Warehouse (it’s a LEGO man toy) and I’m not sure what it would be bettter for people looking for some exercises or tutorials, to show this way or the way using RoundCorner.
It’s true that RoundCorner makes it fast, easy and perfect but the intention of the tutorial would be that people like me can learn something so I’m not sure about what method would be the best choice.
I would guess that when you zoom in close enough you will see this
Follow Me doesn’t want to turn a corner with a zero radius. Some other modellers fail this test too (Revit, for instance)
I don’t have the file now but I will keep making some tries and taking in consideration what you told me.
Related to my last post.
With extensions they will get a result faster but they could think it’s not possible to do it without extensions, and if the extension is not available for them some day (only an assumption) they could not know how to go ahead.
Without extensions they could learn maybe more about the standard tools.
So I’m not sure what choice would be the best for a tutorial.
