I am drawing a multi page construction doc. I am having problems with being able to number each page differently. Either every page is the same number or no number shows up at all.
For example I want my pages to go A1.1, A1.2, A1.3, A 2.1, A2.2, E 1.1, E1.2, etc.
Probably the easiest method if I can figure it out would to simply put in the numbering manually which I have no problem doing.
When I try that layout automatically puts the same number on every page, even after I took out the auto text.
My title block is saved as a group so that is shows up on all my pages. The page numbers go at the bottom of the title block.
You can use Auto Text to add the numbers and let it pick up Page Numbers or Page Names automatically. Page Names probably makes the most sense because you can set the page names in the Pages panel and when you want to go to a specific page, i.e A2.2, you can select it from the Pages list.
You could create a couple of auto texts on a template file and place them on a string of text, next to each other. Something like this:
A.1.Open PageNumA Close (I can not use the actual smaller than or bigger than character)
and set all these parameters per layout file.
You can also have different autotexts for page numbering, with different starting pages. All this can be set in the autotext pane.
The page number text would be on regular layer, not a shared one.
It´s a bit cumbersome but should work. I would do this only if the document has many pages, otherwise, I would use Open PageName Close instead.
