Hi what can I use or how can I divide this building facade that is shaped like a sail
it is concave and has balconies all the way long
only the top floors are differently shaped
I am at a loss how to divide it
does every floor need different sizes windows?
the 2 x two vertical lines are the areas for the elevators
Hello Mr John
Thank you for your suggestion
here is the model
I made a big block and put the sail in the middle of it
then and clicked on INTERSECT with MODEL
But I guess that was the wrong way (problem maybe is that once the sail is inside the block
I cant see it anymore
Thanks for any further hint and help
Ragards
Vic
Hello Thank you very much. I did finally manage to download it
But sadly my curves are all concave every where
I finally did it all by hand following the hidden geometry
It may not be 1005 correct but should be good enough for a rendering for the concept
Now I am looking how to divide more than thirty different length of balconies b
banisters and balustrades. I also need to put condo dividers on the balconies
yet can’t decide if I put them all in the same position
as I have NOT AT ALL designed any inside layout be the elevator shafts
I have push pulled all the window frames (sliding windows etc would be for someone else)
Now the back I have all these frames OPEN
how and where do I click to close them all or many at the same time and create
closed window frame panes?
Please ignore the colours of the materials as I want to make a Lumion Rendering
and need different materials
