I have trying to design a “pushed-in” oval -shape, I’ve been looking for extensions for helping with designing/building and sand box seems to be getting me closer to desired result, but can’t really make it. Would someone be able to guide me on designing this shape
Having more data about that shape, I used a different technique to create a Mid-poly model, with other extensions. SKP model as an idea - lampa-03-web.skp (538.3 KB)
With FredoSpline (or Bezier Spline) I created 4 splines (paths) in the three planes (XY, XZ, YZ) with a specific number of segments.
With TIG Extrude Tools > Extrude Edges by Rails I created the quad surface.
With thomthom QuadFace Tools > Unwrap UV Grid I created the flat surface (group), over which I drew the new surface with holes.
Then I used Caul Flowify and created the final shape (only a part of it). Then with the TIG Mirror plugin you can create the whole model.
Depending on how detailed you want to create the model, you change its flat shape, then apply it over the 3D one (with Flowify).
I guess it’s a good exercise to see if you could replicate it in Sketchup y
Especially as it’s a very detailed product model, so it is going to be pretty performance intensive
That’s what I planned and it’s a combination of the number of spline segments and the Unwrap UV Grid (and with the help of Extrude Tools, which creates quads). This will tell Flowify where to map geometry over quads.
