How to change default setting for text Leader to pushpin
I have set my Text Leader Line to Pushpin under Model Info-Text-Leaderlines. However when adding new text to my models, no leader appears - I still have to manually change it each time I add text.
I know we can change all leader text to the setting I need in one step using Model Info, however how do I get text to have a pushpin leader by default so it just does it.
The normal default should be Pushpin If you’ve changed it to View Based, select the labels, change the Leader to Pushpin and then click Update selected text. After doing that additional labels should also use Pushpin for the leaders. If this is an ongoing thing, check your default template, correct it if needed, and save as a new default template.
