I am trying to get the siding to intersect on this house I’m working on in sketchup. I can’t seem to figure out how to intersect the two pieces of siding. I would compare what I’m trying to describe as ‘fillet.’
I need the siding to wrap around the corner seamlessly.
It would be rather challenging to get it right with a lap siding like that, easier when using this type:
Mitered corners are quite common here with this kind of siding, especially in houses from the 1940s and 1950s.
If i can get the same look using a texture let me know where to look.
the geometry is clear, I wasn’t aware of the ‘follow me’ tool. maybe there is a video somewhere on how to use that.
Never seen mitered corners over here in the Netherlands with what is called “Swedish rabat”.
Usual way for outside as well as inside corners here is to butt them against a square piece placed vertical in the corners…
