How do i export a rendered model?
Hey guys!
I am currenty drawing up the exterior of a building im designing for uni and i am attempting to render it at the same time. When it comes to exporting the model the first problem is that the ‘skeleton’ of the build is the only thing that exports and the faces dont. Any rendering i add also doesn’t export and i have no clue how to fix it… Im very new to sketchup so tips and tricks would be appreciated!
Thanks a lot guys :slight_smile:
Which export format?
How do you add a rendering to your model?
2D Graphic mate, and as for the render i use the materials given by sketchup… is there another way i should be rendering? i would normall import into photoshop and use that but i was just taking advantage as the materials list given to me by sketchup! :slight_smile: many thanks
Wireframe output instead of filled faces is an indication of deficient OpenGL support in your graphics card driver. Try updating the driver, or turn off “Hardware acceleration” in Window menu>Preferences>OpenGL when exporting. SketchUp must be restarted for the change to take effect.
Anssi
