JG01
              1
              How do i bring this image down in the 3d model to be on top of each other?
<div data-theme-tiles="1">
[sketchupwhitehouse.skp|attachment](upload://565YS6nxm6gcEOo281iTJEEccJf.skp) (668.6 KB)
</div>
</div>
Thanks
              sketchupwhitehouse.skp (668.6 KB)
hi, not sure what you tried to do with all the divs and code snippets, but this is a markdown forum, it doesn’t work.
after removing the ``` in your post, we should see the things in mine.
              now, your dwg has elements that have a z value higher than 0
it’s a 2 step solution in sketchup.
step 1, get the extension “Eneroth flatten to plane”. it’s free
step 2, turn ALL the tags visible (one is currently hidden), enter the dwg’s component, select all, and go to extension / eneroth flatten to plane.
step 3 (I lied) Rejoice
sketchupwhitehouse.skp (657.9 KB)
there are similar solutions in autocad, freecad, powercadd and all the other cads, but I don’t know them.
in autocad and bricscad, use the “flatten” command
                JG01
              5
              I’m a newbie as you can tell, yea I’m sure why the previous message wasn’t formatted correctly. Hope fully this comes out okay.
Thank you so much I manage to bring it down to earth
                Anssi
              6
              Without an extension:
Go to top view, set camera to parallel projection.
Export to DWG to full scale
Import
