primarily itâs a âStyleâ setting, most likely a âCustom Styleâ, but may be one built into SUâŚ
The stonework looks like it has been Composited in other softwareâŚ
was there a tutorial or link with the image?
Window (menu) > Shadows (dialog)
Click the âShow/Hide Shadowsâ button in the upper-left corner.
Adjust your shadow properties to suit.
Adjust your modelâs North angle to suit. (Use the NorthAngle plugin from the Trimble DevTeam. Itâs on the Extension Warehouse.)
[It may help to Geo-Locate the model, and set whatever time of day and date, to get the angle of shadows you desire. The location can be bogus (ie, you can set it on the equator, at the prime meridian) just for the scene page that your rendering. Then you can set it back.]
Window (menu) > Styles (dialog)
Switch to a Scene page for your render. Window (menu) > Scenes (dialog)
Back in the Styles dialog, change to one of the pencil styles. Check in the âSketchy Edgesâ or âStyle Builder Competition Winnersâ collections first.
Switch to the Edit tab in the Styles Manager, and tweek properties to suit.
When satisfied, update the scene page via the Scenes manager, by being sure the âStyle and Fogâ box is checked, then click the Update button at the upper-left of the dialog.
Landscape
You may need to find âSketchyâ tree and shrub components in the 3D Warehouse, or SketchUcation Store.
I think the stonework is just the material âSketchy_Stone_Ashlarâ in the stock âSketchyâ materials library in SketchUp.
Nice digs! As Iâve always said, whether youâre rich or poor, itâs nice to have money!
Thank you.
There was no tutorial, this is an image that I found from a firm.
