Hello. I use Sketchup Pro 2022 on Windows 64-bit. I need help modeling vertical gardens on a curved column surface. I found a vertical garden from warehouse that I like and I want to arrange all the groups and components from that along my curved surfaces. I’m not sure how to do this.
I tried following along but I dont get the red lines like in the tutorial after adding my group to hosts. How can I fix that? Is there something else i need to click?
in the area that says ‘Scattered Objects’…you need to select your plant component(s). You may also have to hit ‘generate’ or regenerate in the top left to see them.
I haven’t watched the tutorial or used skatter in a long time, but perhaps the fact the cylinder faces are reversed is an issue. It also would appear to be odd to set the Projection to the z axis. I may well be wrong on both things.
