how can I edit the slash length in the dimension
The best way is to click the
Dropped off to sleep in mid-sentence there, @Box?
You can select the end style in the model info window, but I don’t think it is possible to modify the slash length.
Yes, Thank you… I wanted to reduce the slash length.
You can do this in Layout that comes with the PRO version.
In SketchUp you cannot edit the slash length.
However, Dimension Text and its Leader Lines can be displayed two ways.
In certain situations you might find one way preferable to the other.
• Points As a fixed text size in relation to the screen.
Model size varies relative to the text with changes in camera position.
Examples:
As you zoom out, the model appears smaller, but the text size on screen remains constant.
As you zoom in, the model appears larger, but the text size on screen remains constant.
• Height As a fixed text size in relation to the model.
Text size is constant relative to the model with changes in camera position.
Examples:
As you zoom out, both the model and the text appear smaller.
As you zoom in, both the model and text appear larger.
The dimension font settings are found at Window > Model Info > Dimensions > Fonts
You can also adjust font size in the Entity Info box.
