How to set dimension in slash style as opposed to arrow style.
Select the existing dimension or the Dimension tool and go to the Shape Style window. Select and change the start and end arrows as desired.
Great. Thanks!
I assume I need to create a template if I want this dimension style as default? It seems there’s no default setting for dimensions.
The setting will remain for the current project but if you want the same setting for future projects, you have to create a new template. It’s not any different than making settings in SketchUp. If you want the same settings there, you have to make a template.
In both cases, when you choose a template, you are simply opening a file like any other file and editing it to add your content.
Thanks!!
