Hello guys, I need a little help. How can I create a surface/block like that fence block?
Hi. Do you NEED it to be bumpy in 3D, or will just building a cube and applying the photo as a texture be sufficient? You could build a cube and size it, then freehand draw bumpy edges and then push/pull the unneeded flat sides.
Applying texture is the best way to achieve the look - if creating excessive geometry would needlessly bog down a model file. But if model complexity isn’t an issue and/or the look is more important, then use Eneroth Fractal Terrain Eroder. You can even push that extension to help make things like stones:
If you want to model the actual bumpy surface itself, you might try Spirix Bumpies:
https://sites.google.com/site/spirixcode/code/spirix_bumpies.rbz
