Hobby mihai.s
ms SESO (Select Edges with Same Orientation)
extension
is a powerful selection utility for SketchUp designed to speed up your modeling workflow. It allows you to instantly select multiple edges based on their orientation in 3D space, regardless of whether they are loose geometry or nested inside complex groups.
Key Features:
  • Context-Aware Selection: Search only in your current active context or perform a Deep Search to find edges hidden inside nested groups and components.
  • Orientation Filters: Select edges that are:
    • Vertical: Parallel to the Blue (Z) axis;
    • Horizontal: Lying on the XY plane;
    • Oblique: All diagonal/non-orthogonal edges;
    • Parallel to Axes: Specifically target Red (X) or Green (Y) directions.
  • Length Constraints: Filter your selection by setting minimum and maximum length values (in cm).
  • Automatic Softening: Optional “Soften & Smooth” feature that applies immediately to all edges matching your criteria.
Smart Feedback:
Results are displayed instantly in the SketchUp Status Bar, keeping your workspace clean.
The extension was created by Gemini AI based on my requirements and the tests I did. Unpublished. For SU2022.
Thanks, Gemini AI!
