Help with Lighting
Good Day all, I am doing a interior project and I am at the rendering stage I have always used blender for everything so this is all very new but I have a lighting feature and I have put rectangle light I have put it at full intensity and yet it does nothing to light up my interior not even the spotlights so very confused weather im using them correctly or there’s a setting im missing ? thanks.
also the glass is not working properly…
Move the lights a little down, in front of the ceiling (now they seem to be inside it) and try again to render.
And check Invisible.
ill give it a go thanks
I did that to no avail but I turned ‘no decay’ on which worked for 2 mins until sketch up crashed
Change Units from Default (Scalar) to Radiant power (W).
ok perfect that has seemed to do the job thank you so much !
one more thing if you look to the right where the glass is it seems warped any fix for this thanks
Looking at the first and last image you posted , what you think is warped glass actually is a curtain I think ? Suppose you would need to adjust settings for the curtain material or remove altogether?
Check to make sure that your glass face is not reversed. You can also apply a thickness to it so that neither side is reversed. See example:
yeah that definatly seems to be the problem ill have a look to see if I can reverse it thanks a lot
No problem. This happens to me occasionally which reminds me to check for reversed faces as I go to avoid issues later :wink: Good luck.
