I am trying to create a dynamic valence that can be resized to variable width/height combinations. I have a plane that has a curve on the bottom, and I need to have both sides line up correctly, the issue I am encountering, however, is that when the dimensions change I need the curve to change shape to line up correctly and preserve the correct top an bottom thicknesses. I believe that I need to be able dynamically control the radius of the curve in the center panel, however I cannot seem to find any way to do this in the component attributes.
The corners of the two center panels should line up with the black line that I circled, if everything is working correctly.
The heights of the ends of both panels correctly adjust to the size of the overall object.
Any help would be greatly appreciated. Thanks!
