Can anyone show me how to create a 3 component outer shell automatically after I explode the component? I am trying to create a dynamic component
Hey, not sure what you are trying do accomplish? What is the end goal of your DC and why do you need to make 3 outer shells to make it? Posting your file with what you have already got will help us help you.
I want to create a DC of a board that can change the radius of curvature.
I saw one similar, and they hid the lines so it looked like a complete board,and i wonder how they can outer shell themselves when labeled
There is no ‘outer shell’ function in the DC extension, you would need a Ruby script to do that. You have the idea of the 3 parts with hidden lines correct, it looks like a single board. The curve can be managed by adjusting the length and width with the LenXY or Z attributes of the curved child component. I still do not understand why you need it to outer shell? Is it for some other extension that needs solid components?
can you help me with the ruby script.
I want to make a DC containing many such curved plates. If I solder each plate individually, it will take a lot of time.
make an in-between component that contains parts (solid groups do not leave residue) then you can select (right click menu) in outliner and outer shell that
Dynamic Mitred Steel UB - Model - 3D Warehouse
this can be the trigger point for the script
note that this can be reinstated with swap with its saved definition, or another with a saveas current size reference, this case lenY
If you’re using opencutlist, then you can do things like this with one level of DC group within the part component without the need to outershell.
can someone tell me what is wrong, i am new to rubi script
entities = Sketchup.active_model.entities
=> #Sketchup::Entities:0x0000014f82bf62b0
dc = entities[0]
=> #Sketchup::ComponentInstance:0x0000014f82746b70
t1 = entities[1]
=> nil
t2 = entities[2]
=> nil
t11 = group1.outer_shell(group2).outer_shell(group3)
Error: #<NameError: undefined local variable or method `group1’ for main:Object>
thanks but this doesn’t work for me
several…
This is okay, however keep in mind:
The #entities method returns an Entities object containing the entities in the root of model.
That is correct, you associated the ComponentInstance - which is the only one at the root of the model - to dc
variable.
as you can see both association is returned nil
(nothing) because the entities collection does not contains the elements with that index.
The error describing that `group1’ is undefined (group2, group3 also not a) method or variable.
In fact, the definition of instance assigned to dc
contains the 3 (group) instances you are looking for.
if you associate like
# make the instance unique, so you will not chage other instances they maybe exist
dc = dc.make_unique
dc_ents = dc.definition.entities
group1 = dc_ents[0]
group2 = dc_ents[1]
group2 = dc_ents[2]
# then you can explode `dc` and get the solid "unwrapped"
dc.explode
You can ask your Ruby related questions in a corresponding category: Ruby API - SketchUp Community
How to post code correctly in the forum:
thanks bro, but it’s still giving me some error. and can i remove the make unique code and replace it with component?
dc = dc.make_unique
group1 = dc_ents[0]
group2 = dc_ents[1]
group2 = dc_ents[2]
then you can explode dc
and get the solid “unwrapped”
dc.explode
Error: #<NoMethodError: undefined method `make_unique’ for nil:NilClass>
PLEASE post your code according Instruktion here:
[How to] Post correctly formatted and colorized code on the forum?
Well. There is a typo in my code above, group2
asgined twice… sorry, I did not tested it yesterday .
the proper one should be:
dc = entities[0]
dc = dc.make_unique
dc_ents = dc.definition.entities.to_a
group1 = dc_ents[0]
group2 = dc_ents[1]
group3 = dc_ents[2]
dc.explode
Be aware that this snippet is handling the special case where there is nothing else in a model, just a component containing, 3 solid groups/component.
Post your model you are trying on, if you still heve an issue.
thanks bro
I want to write code to automatically outer shell DC when switching from component to group, can you guide me. Or where can i find references
I don’t quite understand what this means.
However I have an idea how to merge (outer shell) solids inside any selected component then explode this selected component.
I guess, it’s okay to merge first inside and then explode the outer component you selected.
I can call it something like “Explode to Solid”.
I’m busy right now, but the evening (CET) I will check.
Please post your model, containing some DCs you are talking about, and I can test on it as well.
Dot Cong.skp (14.8 KB)
I mean link the ruby code to this DC, so when I use explode it will automatically outer shell.
sorry for my confusing writing. i used google translate
hm. trouble is it’s translating what you need literally, but outer shell is also a tool in sketchup, hence the confusion.
can you tell us in your language ? chances are someone understands, or at least can check with other translating tools ?
Tôi muốn tìm hiểu về cách làm cho Dynamic component của mình liên kết với 1 mã Ruby . Để khi tôi explode nó từ Component ra Group, nó sẽ tự hàn những group con bên trong.
