I myself don’t know of a way to make DC start a code, and moreover, in a way that happens when you explode it so that it is not anymore a DC.
Well, actually there is a methods to attach observers to model/instance to listen if its exploded or not, but much easer to write a code to do explositon like the native one.
So, I will give you a code, which supply you a context menu (similar than the native “Explode”), but this will be “Explode to Solid”, so if the selected component(s) contains nested solid groups/components what can be merged (weld, outer_shell-et), then it will be merged, than the DC will exploded.
Stay tuned…
This is an unsigned TEST plugin, does not properly made to call as Extension. But you can install it like an extension. If you don’t know how to do it, better to not to do it. Dezmo_explode_to_solid.rbz (786 Bytes)
You need to right click on the component (or group) and chose “Explode to Solid”.
You can also select more components/groups or everything, the code will examine if there is a component/group which contains at least two solid components or groups and merge them using outer_shell method, then explode.
The name of the resulting solid group will be the instance name of original component/group (the outer one.) If there is no instance name, then the definition name will be used.
You can undo it, all at once.
No Warranty. Use at your own risk!
Tested only very-very limited time, in Windows 11, using SU2022. Warning! During my test when I undo-ed the “Explode to Solid”, once I get a bug-splat. It may not related, but maybe yes. Be careful! Make a backup, before you use this plugin.
Don’t say I didn’t told you!
The code, for reference:
module Dezmo
module ExplodeToSolid
extend self
@@loaded = false unless defined?(@@loaded)
def instance?(ent)
ent.is_a?(Sketchup::Group) || ent.is_a?(Sketchup::ComponentInstance)
end
def solids(ents)
ents.select{|ent| instance?(ent) && ent.manifold?}
end
def parent_instances(model = Sketchup.active_model)
sel = model.selection
sel.select{|ent| instance?(ent)}
end
def new_name(instance)
case instance
when Sketchup::ComponentInstance
if instance.name == ""
instance.definition.name
else
instance.name
end
when Sketchup::Group
instance.name
else
end
end
def explode_to_solid
done = 0
model.start_operation("Explode to Solid", true)
parent_instances(model).each{|instance|
ents = solids( instance.definition.entities )
solid_count = ents.size
next if solid_count < 2
group_name = new_name(instance)
instance = instance.make_unique
ents = solids( instance.definition.entities.to_a )
e0 = ents[0]
group = nil
solid_count.times{|i|
next if i == 0
group = e0.outer_shell(ents[i])
group.name = group_name
e0 = group
instance.explode
done += 1
model.commit_operation
UI.messagebox("#{done} solid(s) created.")
end
unless @@loaded
@@loaded = true
cmd1 = UI::Command.new("Explode to Solid"){
explode_to_solid()
UI.add_context_menu_handler do |menu|
if !(parent_instances.empty?)
menu.add_item( cmd1 )
end
end
end
end
end
Finally, I’ll move this topic to the Ruby API category, as this is more about talking about code.
thanks bro, but maybe i was wrong to ask about ruby. because i happened to have a dynamic component, and it works without Extension,maybe i need to do a little more research
I am going to try one more time bro. Why do you NEED it to outershell? What are you doing with the component after it is made into an outershell, that CAN NOT be done with the 3 part component?
What you showed in the video is done on the ABF extension side (ruby). It is an observer that responds to certain actions and attributes in a dynamic component.
