i need help to re draw the attahced pictuture.
I managed to draw the main steal beams. 5 of them, each one in on a different level
but i have a problem getting the wood beams fall across of the steal beams, and taking that curved shape…
i am familier with most options on sketchup, but this picture is too complicated to me.
Before investing too much of my life in this, is this the general idea or am I missing something?
-Gully
wow …how did u do that too quick
its right …but the wood beam is one piece from start till end therefore the wood beams will be bent, not 4 straight pieces.
I found some more pictures of these structures … http://www.unopiu.com/pergole/pergole-autoportanti/wave/188/91/252062/ … very reminiscent of the Conestoga wagons!
Obviously, the slats are the hard part. Right now, making them is rather laborious, so I’m going to study on how to make them more easily.
-Gully
Seems like there should be a way using spline curves…isn’t that where they originated?
In other words, draw splines between points on the bows and use those as follow-me paths for a rectangular profile of the slat.
Here’s a quick-cut example of what I mean. This was done as follows:
drew the arches (for quickness, just as lines)
drew a small rectangular profile for the slats, moved and aligned it with the base of an arch
drew a cubic spline through the bottom points of the arches
did follow-me of the rectangle along the spline
made a component of the extruded slat
rotated a copy up to the next vertex on the arch
did 24x to create the rest (I had drawn the arches with 24 sides)
You could refine the shape by choosing a different kind of spline or tweaking the control points.
Jeff
April 9, 2015, 10:07pm
8
this isn’t right… the slats extrude wrong and would be a pita to get them proper…
(you’d have to put the profile on each end of each spline at proper orientation then curviloft’s ‘Loft along path’ to deal with the twisting boards)
but just for ideas:
extensions = Fredo’s Bezier Spline, Curvizard, Curviloft… Whaat’s Profile Builder Free.
• classic bezier curves … i drew three then rotated/copy for the other three.
• Bezier Segmentor to increase segment count
• CurviLoft loft tool -
'Smooth Global Junction by single b-spline" method
“Generate the junction edges (no face)”
• Profile Builder
profile builder
Jeff
April 9, 2015, 11:19pm
9
using this new plugin… Flowify :
http://sketchucation.com/forums/viewtopic.php?f=323&t=61363
this is the first time i used it… took about 10 minutes to figure out how to use it but only a couple of minutes to make this:
(flat array of boards flowed over a curviloft skin )
Shep
April 9, 2015, 11:28pm
10
@Jeff That looks really slick. I’m wondering if the slat width or the spacing varies. Seems like they couldn’t remain constant along the length.
Shep
Jeff
April 9, 2015, 11:33pm
11
I’ll check in a little bit. on a phone now
yeah, both the boards and the spacing are shrinking in the middle… realistically, the boards would stay consistent and the spacing would get smaller…
idk, if it’s for archviz only, it’s probably ok.
@Jeff , most impressive. Nicely done.
-Gully
I followed slbaumgartner’s example, it’s easy and doesn’t take much time. Glad I took a look at this, I learned something new.
