2024-12-10T23:00:00Z
How to create a roand stair!
trap.skp (503,4 KB)
There is probably too little headroom to fill the code. Otherwise everyone would be building them like this
Thanks, The spiral staircase has a slanted [77 degrees] center pole! The step connection with the pole are therefore all different. The turn of the 13 steps upwards is 180 degrees. The floor height is 292 cm. [292/13=20.8cm].
The 14th step is the floor. [14x20.8=291.2 cm]
Thanks, The spiral staircase has a slanted 77 degrees center pole! The step connection with the pole are therefore all different. The turn of the 13 steps upwards is 180 degrees. The floor height is 292 cm. 292/13=20.8cm.
The 14th step is the floor. 14x20.8=291.2 cm
Make sure that the height and depth of the steps are conforming to your local code.
