HELP! Extension Error Load on Start up
Installed ams_lib extension plugin in the extension warehouse but keeps getting this error. How do i go about it?
Error Loading File C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/main.rb
Error: #<LoadError: An exception occurred while loading ams_Lib, version 3.5.2!
126: The specified module could not be found. - C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/libraries/3.5.2/win64/2.7/ams_lib.so>
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/extension_manager.rb:305:in `block in require_all’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/extension_manager.rb:301:in `each’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/extension_manager.rb:301:in `require_all’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib/main.rb:129:in `<top (required)>’
C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in `require’
C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in `load’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib.rb:23:in `register_extension’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib.rb:23:in `module:Lib’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib.rb:7:in `module:AMS’
C:/Users/lmgdb/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/ams_Lib.rb:5:in `<top (required)>’
According to the Extension Warehouse the last SketchUp version the extension shows compatibility for is SketchUp 2017 and the last update was in 2014.
Screenshot - 4_18_2023 , 9_19_23 AM
You might contact the author and see if they have an updated version available.
Edit: remove that old version from your Plugins folder and try the newer version from Sketchucation. It was updated in 2021 anyway.
THANK YOU! That works for me ! Yay!!
