Goodmorning. First post here and new to Sketchup.
I’m getting the grips with this wonderful software but now I’m stuck
Looking to enlarge the whole on the top off box. There is two holes stepped. The top hole it’s 15mm and I whould like to enlarge it to 16mm and also i would like to adjust the depth too… but not sure how much right now till I do a test print… I’m stuck, so I’m looking for help please.
An explanation on how to do it would be much appreciated.
Dave beat me to it! STL is not SketchUp’s native file format, and because STL uses exclusively triangles to represent surfaces whereas SketchUp uses arbitrary shaped planar faces, exporting to STL and then importing back to SketchUp will usually result in very different geometry!
You can probably erase many of those coplanar edges forming the triangles but not all of the edges are coplanar and some of them shouldn’t be there… Personally, at this stage I would just start over since you need to clean it up and you want to modify it.
Dave the dimensions are spot on. But my fault I uploaded the wrong file lol. This is the file with the 22mm hole not the 15mm. No matter though same file and same problem lol.
It’s a 3 minute model once you learn how to use the basics of the software.
It’s a 3 hour headache if you try to modify something produced in another format.
That’s not any better than the SKP or STL file you posted earlier. Imported with millimeters as the units, it shows the same dimensions and it has the same garbage to deal with.
