Actually I just measured the box and those measurements are spot on
Spot on to 6 places right of the decimal?
In your original post you said: [quote=“panosgerontis, post:1, topic:30017”]
The top hole it’s 15mm and I whould like to enlarge it to 16mm
[/quote]
Neither hole is 15mm in diameter.
Dave I know was my fault. I uploaded the file with the 22mm hole. but I can adjust it later if I can. so yes 22mm on that file it’s correct. all the rest are the same dimensions
As I said, the one I drew had dimensions rounded to the nearest half mm. Well, except for that tab. I put it 0.6mm from the end wall. I guess my dimensions weren’t correct, though. I didn’t bother to keep it. You should find it a good project for learning SketchUp.
You teasing me now lol.
Thanks ever so much for your time though Dave.
I give it a go my self.
But if you still got the file you made I can play with it maybe?
Many thanks
As I said,
Not teasing you.
I know Dave.
Again thank for all you done.
