Help cutting out curved form on curved form
Hi everyone!
I’m working on a project however I never had sketchup lessons or nothing so I«m having some trouble. I want to do a shiplap on a curved wall, however I have curved windows on that wall . I was able to cut out the form freehand on 2 windows but it’s not working now as I expected.
Here is the situation: I ton of lines because I am a noob.
Could someone help me do this?
Doing the subtract or how you call it doesn’t work, it says none of them are solids, and I already used that on the wall for the window.
Thanks a million!!!
PS. how do I upload a file?
Do you know what a solid group is in SketchUp?
if the file is small enough drop it into a response window here on the forum. Otherwise upload it to a file sharing service as suggested and post the link. Most likely you are going to want to make your shiplap wall a solid and subtract the windows but let’s see your file.
Sorry, kids got sick so wasn’t able to come on my computer a lot.
Here is the link to the file: https://drive.google.com/file/d/1Tb14gP-3j9yHIPTfRN9TFpkeB47Rzv1M/view?usp=sharing
Using Fredo JPP extension
But you can do everything just using PushPull and Solid Tools (it involves a little more work).
Thank you sooo much!!! I can’t find the extension, is it the FredoTools? I can also not find it on their website Extensions | SketchUcation
Would you mind sending me this file so I can put it in my model? I am unfortunately not yet very good but will be investing in some sketchup courses when I’m able.
I used the file just to show a working method, but without saving it. File deleted.
Google search
Thank you, found it! Unfortunately won’t be able to use as I don’t have the money. But I really appreciate it! Do you have any other idea how I can do this shiplap wall for free?
You can draw the boards using the basic tools:
Thank you for your reply! I did that but I don’t know how to cut out the holes for the windows
Draw around the window opening with the pencil and arc tools till you have a face the shape of the window. Push pull it out and make it a solid group. Use the Trim tool to cut away the shiplap boards.
With native tools (SketchUp Make, Pro, Web, iPad)
PushPull and Intersect Faces
Basics of SketchUp at Campus:
Life saver!! Thank you soooo much!!! It works for me and my beginner skills and it looks perfect! Thank you!!
Good for you, you learned a new thing today!
Now you can start steaming the shiplap to get it bend. :grin:
One reason to use a vertical board and batten siding. But monks went around in horsehair shirts, too.
I am guilty of one exterior wall with an arch shape. It was covered with factory-bent corrugated steel sheets.
