Hi.
I have recently acquired a topcon gps system, which I use on site to collect some data. Within the system (Magnet field), I can create lines, points, offsets, angles, basically I can create a floor plan from scratch within the data logger, but it is a pain and slow.
I got sketchup pro with the plan of importing the (Accurate to within 5mm) points I take, and editing them to create my design or space (foundations, shed bases, patios, walls, pipes etc) and then export back to my gps system so I can layout a site quickly and efficiently.
My issue is this, when I create my plans from within the system, it works perfectly. I am in Northern Ireland. When I import the points to sketchup and try edit, a lot of the times the points cloud disappears on me when I’m panning around and moving. However the main thing that bugs me is when I geolocate this, or add a location, my points are either near Norway, or else near France. I have tried 3 things ;
I have added the location first, imported my points and moved them to the geolocation of where they are supposed to be, and exported.
I have created a new file, imported my points and just directly exported them again.
I have imported, added location, and kept points where they are, and exported.
Every time I export and open the file on my gps, I am about 1500km away, in random directions, sometimes north, sometimes south. This is no use to my gps system as I got it to make my life easier, not more stressful!
I have been contacting topcon support, they suggested changing the import units from meters to mm, and everything else but I tried all this and nothing helped. I have contacted sketchup support but they aren’t fully sure and have told me to try post here because maybe (Hopefully) someone will have experience of this!
I thank you in advance, and if anyone wants some screengrabs posted, let me know and I will get them to you within a day or so.
Thank you, Happy modelling!
