Good afternoon,
I have an issue in Sketchup where a ghost plane is blocking my entry to the cellar.
This is the view from up:
However, I am also not able to select that to delete.
Help would be appreciated.
Share the .skp file so we can see what you are working with. I expect the problem and fix is easy enough to identify if we can see your SketchUp model.
Like requested
House to-be.zip (7.0 MB)
Opening it now. Note you shared the .skb back file, not the .skp model file so it may not be the most current version.
House to-be.zip (6.8 MB)
This is the skp file.
That’s the shadow of the adjacent wall being cast on the ground plane.
Shadow? What do you see?
The "ghost face is due to having Shadows turned on and On Ground enabled. Turn off Shadows while you are working.
Your model needs a lot of help. Most of the faces are reversed (there should be no exposed blue back faces) and it’s almost all loose geometry. You need to learn about using groups and components.
Thank you DaveR.
Thank you! It is gone indeed now.
I will learn it in the near future from scratch and correctly, but I don’t have time for that currently.
On Friday we need to visit the architect with our idea how to rebuild our house and get him to work.
I am aware this is below standard compared with professional users, this is the first time I use Sketchup, but as long I get the message correct to the architect to indicate our needs it is fine by me for now.
