Hi, I’m having trouble creating a 3D solid form of a triangular wall. All the facets are set at an angle and I am currently using a Rhino file as my reference to create the thickness of each triangular panel but for some reason, I can’t close off some of the panels and they 3d wall~~~.skp (3.9 MB) do not form a solid plane. The lines on the Rhino file are quite inaccurate because of the angles and thickness, which means that I have to find each individual angle to make sure they join. Any advice on how I could possibly resolve this? Thank you.
Hi,
Thank you so much! I’ll have to try this. Where did you download the plug in?
You’re welcome!
From Sketchucation - Fredo6: Joint Push Pull Interactive
