Generate Report Template not importing
So must be a Tuesday… I cannot import a template to the generate report window in 2024… Anybody else?
EDIT: Template file text, can’t post the file.
{"id":"kuq40rxsf6p8","title":"Component Quantities Report","utcCreationDate":{"date":"2021-01-23T01:23:48.465Z"},"author":"SketchUp","description":"This is a sample template that illustrates a new reporting capability that allows you to group components by definition. This reporting template will output a report that includes a column for quantities. You can run this reporting template by clicking the run button below. You can modify this reporting template to include other types of attribute data by clicking the edit button below. You also have the option to duplicate this report and edit the duplicated reporting template.","groupedAttributes":["dyc:AA_CATEGORY","dyc:AA_LIST_NAME"],"attributes":["dyc:AA_QUANTITY","dyc:AA_UNITS","dyc:AA_SPEC"],"useCurrentSelection":true,"depths":null,"copyNumber":0,"unitFormat":"decimal - inches","unitPrecision":"inch","version":"1.0","options":{"injectedForCompCount":true,"attributeDisplay":{"dyc:AA_QUANTITY":{"displayName":"AA_QUANTITY","aggregationType":"sum"}}}}
On further investigation the report does import, it just does not appear in the templates list after import…
After importing screen shots:
You can see all the info is imported and set, just not available in the template selections.
On further investigation I realise that the import just fails, it does not bring in the template at all. Tried making a brand new template and saving it, but it still will not import to a new file.
I just exported a grt and the format looks a little different that what you are showing:
{"numberOfUntitledTemplates":0,"id":"683cd5c7ed42","title":"Component Quantities Report","utcCreationDate":"2025-02-04T23:25:00.315Z","author":"SketchUp","description":"This is a sample template that illustrates a new reporting capability that allows you to group components by definition. This reporting template will output a report that includes a column for quantities. You can run this reporting template by clicking the run button below. You can modify this reporting template to include other types of attribute data by clicking the edit button below. You also have the option to duplicate this report and edit the duplicated reporting template.","groupedAttributes":["Definition Name"],"attributes":["Quantity"],"useCurrentSelection":false,"depths":null,"copyNumber":0,"unitFormat":"architectural","unitPrecision":"sixteenth","version":"1.0","options":{"injectedForCompCount":true}}
So it would appear that my template file was corrupted somehow? Loaded an old .skp file with the template already saved to the model, re exported the .grt and it’s fine now. Gremlins I suspect…
Also yeah they are different eh? My .grt file is missing this at the beginning: “numberOfUntitledTemplates”:0,
Could be? I don’t have any saved templates, so “numberOfUntitledTemplates”:0, makes sense… and does look like a missing field compared to your example.
Do you have an extension that is modifying dynamic components attribute dictionaries? Maybe something is being truncated/incorrectly formatted? Gremlins in the DC code?
No extensions doing anything with grt. Gonna chalk it up to weirdness and move on. Plenty of other fish to fry.
Agreed. Just mentioning because there are those little gremlins where your html/javascript/etc. aren’t passed correctly:
Screenshot 2025-02-05 144210
And dynamic component dictionaries are messy:
So, a little mishap somewhere could cause gremlin instability with the mogwai within the DC extension black box. Or at least that’s a conclusion I can live with.
