Generate Report acting strangely with dynamic attribute visibility in Options Dialog
So I am running into this bug where the value of a custom dynamic attribute in a component does not appear in generate report.
I thought maybe if I remove the attribute from my generate report template and bring it back in again it might fix it. Instead the attribute completely disappeared as a reporting option, even though it was still appeared in the 2 components in the model.
Next I removed the attribute from one of the board components in the file and re applied it. All of a sudden it’s back as an option in generate report, and populating with the name. Running a report on the two boards you can see one works and one doesn’t.
Gen Report broken.skp (1.9 MB)
Anyone else experiencing any weirdness with generate report lately? I had this happen recently as well, wondering if it’s all connected somehow. Any insight appreciated…
So I figured it out. Exposing the attribute as visible in the options dialog caused this.
Simply making it invisible to the options panel fixed it.
