Hi, I have been developing in the last few weeks a script to create assets and automatically fill in the dynamic attributes.
These functions have worked correctly, however when
I insert these generated assets into a project and generate the report, these filled attributes do not appear in the report, but all the others manually filled appear. Has anyone experienced the same and found a solution?
Also, both the definition and it’s instances have "dynamic_attributes" dictionaries.
When the instances have attribute values that differ from the default, the values are stored in the instance’s dynamic dictionary.
Even in the saved file it appears in the report, but when I import the file inside another the attribute disappears from the report but stays in that dynamic attribute tab.
I ran with the component and with the instance, but even so the problem persists.
Well, past a few months the error came back, i’ve tried these two suggestions but neither worked. i’d just workarounded these last months, but now i can’t anymore. Let me explain what’s happening now.
I’ve created a script to open a list of component in an irrelevant sketchup file then set up some dynamic attributes, like iditem, description, etc… then saved them in a proper file
But when i import these component assets inside a project i can see the dynamic attributes in component attributes tab, but looking inside component option got the followed error:
Tried use the plugin created by Eneroth “Attribute Editor” but the dynamic ones only shows the attributes “_has_movetool_behaviors” and “_hasbehaviors”, like showed below.
Have you considered to export your SketchUp model to Trimble Connect? You can generate a report in CSV format and you can find more parameters than in the SketchUp report.
This means that when the instance does not have values that differ from the definition’s default values, then the instance’s dictionary will not have these DC attributes. So in this case, the value must be taken from the component definition’s dynamic dictionary.
I would suggest using Aerilius’ Attribute Inspector extension. You can choose to look at the selected instance’s definition’s dictionaries using this inspector.
