Hi,
I see that this topic was already relevant three years ago, but it did not receive the attention of the developers. Therefore, I will repeat it as a feature request.
It is possible that this should not be a report at all, but another way to export the content visible in the outline window - exactly as it is seen, in several subordinate levels, but not as a picture, everyone can take screenshots. Of course, it would be nice if it were possible to group identical elements, indicating their number in a particular set.
It is often necessary to indicate such information in drawings, but creating it with Generate Report is very time-consuming if the number of such elements reaches tens and hundreds.
For example, this is an outline of only one gandparent element (not even the whole one). As you can see, many definitions are represented in several instances, which would be desirable to combine and give their total number within the parent element (not in the entire model).
Thank you in advance if anyone has the courage to finally solve this issue.
