Gaps in arrow heads in Layout
I am getting gaps in the arrow heads for notes and the line ends (see attached). I change the arrows to another type (open versus solid fill) and that cures the ussue but then the gap returns. Any one notice the same? Any of those found a solution?
I can’t duplicate this. Can you share a LO file that shows it?
It couldn’t be the text box or something else besides the leader, could it?
Sure I’ll breakout one sheet.
Send it via PM if you want.
I can’t see it in your file, either.
The label and its leaders here are on the Graphics layer. What happens if you move them to the Labels layer? Does it change anything?
Uploading: Gap arrows.layout…
Acctually I closed the file to delete all sheets but one to send to you. Now when I reopen the file, all the arrow heads are correct. I having several issues along this line. I have experiencing lock ups (endless spinning wheel), long file refreshes, and crashes. When I reopen the file, typically all is well and the program works much faster on file refreshes. Maybe like a memory leak or?
That may be. I’ve been poking around your LO file as if I were working on it but so far no joy on inducing those gaps to appear.
This may also be something Mac-specific.
I see some unrelated things but you may not care about those.
Sure I care for comments from someone as experienced as you. What do you see?
Since it’s off topic I’ll send you a PM.
