Functional Stability of Dynamic Components
Do you know if Trimble is seriously working on improving the stability of its dynamic components?
I’m currently designing several components that use a user input window, but randomly, this window remains empty of fields that were working perfectly five minutes earlier.
Do you have any advice on how to resolve this bug?
Thank you in advance.
Sincerely,
________________________________________________________________
Stabilité Fonctionnel des composants dynamiques
Bonsoir,
Savez-vous si Trimble travail sérieusement à améliorer la stabilité de fonctionnement des composants dynamiques ?
Je travail à concevoir en ce moment plusieurs composants qui font appels à la fenêtre de saisie utilisateur hors, aléatoirement cette fenêtre reste vide des champs mis en place et qui fonctionné cinq minutes avant.
Avez-vous quelques conseils pour résoudre ce bug,
D’avance merci
Cordialement
I don’t know if the problem will be fixed, but I do know what leads to the issue. Read this post I made a few years ago:
The secret is to select the component before opening those panels, then they will work ok.
I would guess not as this bug is YEARS old. The last version update was a bit over 2 and a half years ago.
It seems as though Trimble is putting money and effort into Live Components instead.
