Hello friends,
I’m having this issue for quite long time now. When I start to render frames with V-ray6/ Sketchup2023 it renders 20-30 frames and then get stuck. I can see time counter still going on but at same frame as shown below. I
Same issue happens if I render animation or just image sequence with V-Ray. without V-Ray it works just fine and progresses to the end. Has anyone faced this issue or any solution ideas. I tried reinstallation but didn’t work.
Thank you so much
What are the specs of your machine? Do you render with gpu or cpu? You could be running out of memory. The next time you render open the task manager (Shift+Ctrl+Esc), there go to performance and check the memory usage.
Thanks francisquitof,
I work on HP ZBook 2.3 GHz i9 with 32 GB Ram. Render engine is CPU
I monitored the performance; memory usage is at around 80% while rendering. Memory usage keep showing 80% even after interrupt render. it goes back to normal only when exit Sketchup.
