I have tried to make my structure for my building for my project however I am having trouble getting the shape of the structure due to its curves. The first picture is the organic shape and the second picture is how I would like to have my structure on the inside. Can someone teach me how to do it or give me a plugin that allows me to use faces to make that happen?
Is there an internal surface for the shape? The back faces seen through the opening at the top make it difficult to tell. If there is an internal face so the thing can be a solid, you could use TIG’s Slicer to slice it to make the ribs. You can get it from Sketchucation.
Yes there is a internal surface, the same shape but smaller by 150mm, the opening to the top is where the window will be placed.
You should correct the face orientation, then. There should be no exposed blue back faces.
Make sure the model is aligned with the axes and set the slicing planes as needed.
