Format de fichier inattendu?
Bonjour,
Je suis une utilisatrice de SketchUp Pro2021.
Je tente, en vain, d’ouvrir un fichier réalisé en 2016 (avec la version Sketchup 2017).
Le message suivant s’affiche toujours à l’ouverture: FORMAT DE FICHIER INATTENDU.
Y a t il quelque chose que je puise faire pour récupérer ce fichier?
Je vous remercie,
Katerine
Translated by Google:
I am a SketchUp Pro2021 user.
I try, in vain, to open a file made in 2016 (with the Sketchup 2017 version).
The following message is always displayed when opening: UNEXPECTED FILE FORMAT.
Is there anything I can do to recover this file?
Perhaps upload the file here. @colin sometimes has luck recovering at least components and materials. He might be successful with your file. If it’s too large to upload directly, upload it to DropBox or Google Drive and share the link.
Please complete your forum profile with Sketchup version. Are you still using Windows 7? If not, please also update your computer information. That information helps us help you.
Bonjour DaveR,
thank you for your quick answer.
Here is the link up to the file:
https://educlgqc-my.sharepoint.com/:u:/g/personal/katerine_brochu_clg_qc_ca/EZGTqXJotN9No3o-VV9gY-oBMQoJa7I7VxTuv_o-Q7Z3mQ?e=9vxUxV
I did update my computer information…Thanks for the recall.
Thank you for your support!
I tried to do something with the file, but it comes out very small sized, I’m not too hopeful. It’s small enough to attach in my reply.
TLG_THEATRE_recovered.skp.zip (3.2 MB)
Curiously, it seems to be a SketchUp 2016 file. What is the reason for that?
Hi Colin,
First, thank you for your quick reply.
I succeed to open it but it showed a blank space. I could not see anything.
The only answer I found for that the problem might be attribuate to the saving supports (Key USB?)
We will have to redo everything….
Thank you for your support.
P.S. : The file has been draft in 2016 and has been archived since. That is why is has be done with 2016 SketchUp version.
Before you start redoing it all, look at the In Model components. There are a bunch of them you can drag out into the model space.
Thank you!
@katerine It’s not a good idea to post your email and phonenumber.
Spambots roam the internet for personal information!
You can edit your post to delete it.
Thank you!
It was done by mistake.
hello Please i have the same problem. i dont know how to fix it .hekp me
If you have the same problem, you can download the already posted file.
If it is a problem with a file of your own, you might want to upload that file.
https://we.tl/t-bftstKxtm6
thank you for the rapid answer this is the link
As with most cases, I recovered the components and materials, but the scene is empty. You would need to rebuild the scene by dragging components back into place.
https://we.tl/t-ERRVQv4GKh
Hello @colin
I am having the same problem as @katerine
I need your help
If you can upload the file somewhere, I can try to open it. Upload the .SKB version as well.
Hello sir
I have fixed the problem
I converted the .skb file to .skp
Thank you for your quick reply
Best regards
Bilal
Dear @colin
I have the same problem : WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Would you please help me ?
Thank you for your help
I was able to recover the file:
Thank you so much Colin !
Do you know why this happened to my file ?
Thank you again and have a good day !
We still don’t know what causes the problem you saw. If you can keep extra backups, then if you see the issue again try to remember what changes you had made. In theory, you could send me the latest working copy, and some ideas of what changes you had made since then, and the same problem should happen to me as well.
