Followme not seeming to follow sections, model size conversion
Hi
Thanks for your message
D is fine although I tried to clean up that made E
I can take all the height measurements
now have learned how to make layers here in SU
I looked again I tried to limit your time and resources made D and E
Tried to read on how to determine which one are not coplaner
There seem to be numerous plugin free or not such as Ruby (that one telling me)
The requested page “/intl/en/redirects/gsu8/rubyapi.html” could not be found.
Tried now for six hours to smooth the curves of the spiral especially on the outer side at N S E W
still without touching the finished balcony
Still don’t get it why some will link with one smooth line other make the segments
and some I just can’t fill them in
Looked from under over many angles desperately trying to zoom in on all the connections
and yest there were (or still are) some connections that were or are a mess no connecting
properly even I see the green dot but I guess it appears as there are several connections concentrated
I work on a 27" monitor and I have near perfect vision
so its very frustrating to see these tiny problems that I would never have imagined
I still can’t see one layer that is higher then another
every time I delete line that makes the edge of a spiral or call it paisley more parts disappear
then I can’t recall where I come from so have to make screen shots each time etc…
0_D_only.skp (118.5 KB)
I think here lies my biggest start problem is how to smooth one curve into the other
I found some (blue circle) that said “tangent to vertex” maybe that is what all should do and
I should have ignored the outer perimeter and then made it when all was done.
I put it here
https://visualsenses.smugmug.com/PRIVATE-GALLERIES/SketchUP-8/i-tNV3XFj
Tried to upload a screenshot of a reduced version to only 47KB it tells me it can only 5KB ??
Is there a limit per message or per day?
Trying to show you not just sit back and wait for someone else to solve my problems
Thank you
Just finished measurements
and here is the balustrade
0_0_new_LAST_REVERSE_PUSH_PULL_E only.skp (522.5 KB)0_D_onlyWITHheightMEASURMENTS.skp (1.0 MB)0_NEW_BABEL_balustradeONEgroup.skp (2.5 MB)
