Hi,
I’m having some problems when I want to drag a curved shape on the inside of at “box”. It creates some blanks in the corners. Does anyone know a way to prevent this, another way to do it or a way to replace the missing surface?
Br
NEJensen
Hi,
Br
NEJensen
What size is the part? SketchUp has trouble with small Edges and Faces - meaning around 0.001 inch. If the follow-me operation creates geometry at or around this small size, the faces will not be created.
If this is a size problem, try to scale the geometry up by a factor of 100, then perform the follow-me operation.
SOLVED:
Perfect ![]()
I’m working with a 140x140mm. Upscale (by a factor 10) → make a new Follow Me → problem solved → Down scale → still solved ![]()
Thanks jim_foltz.
Br
NEJensen
