Soooo…. You have figured out how to have folders for tags…. How about folders for components. I have so many different component types at different scales and purposes eg: doors, windows, - Floor levels - special parts - dimension lumber, building materials - and so on…… the list gets really long and messy…. No matter how hard I try to code stuff.
I agree 100%. I find the in model components window basically useless after a model gets to a certain size. Even if there was an option to just show the current selection (1 or multiple) in the components window, instead of the entire model. Or if the existing 3D warehouse search bar could search in the current model also.
What you want to archive with Folder for Component? Classify or control visibility? Why not using tag for “folder”? Assign all door components to tag named Doors, etc… Tag system and nested components can.
I believe the OP is asking for a simple hierarchical structure within the In Model section of the component browser. Something that can’t be achieved with Tags.
I guess ‘we’ need them component folders to filter full-components and parts-of-components.
Just as a model can contain multiple tags, it would be nice to be able to make folders for specific component parts.
This way full-components are way faster to find inside the components list, spacially when you have for exsample 100 components with 10.000 seperate parts wich can not be groups since many of them are a like and used in multiple components. you may need to scroll down 10.100 parts to find the sepcific component you need, OR you only need to scroll down 110 (100 components + 10 part folders) to find the same component.
Do i still make sence? Anywho would be a much appreciated future feature ![]()
This would mean the world! And imagine (pipe dream) if you had a component browser in Layout where you could just drag a component from inside a model onto a page to create a few basic viewports.
To clarify my original feature request: I was referring to the in-model component browser. I use components for many different scales and types of building parts. From a single window mullion or wood stud, to custom doors and windows, to floor plates and walls, to entire parts of buildings. The problem is - despite my best efforts of using prefixes etc in the naming of these components the list in the browser gets ridiculously long and it is very difficult and time consuming to find a particular item. If there were folders, I could sort them into categories such as ‘doors’, ‘windows’, ‘floor assemblies’, ‘fittings’ etc. Then if the folders that I I am not using can be closed (little triangle thingy) then my list of components that I am looking for would be much easier to navigate…… I am sure this would be useful to most people as the guru say ‘everything should be in a group or component’(?)
Yes, what you want can be accomplished. Use the details arrow on the right side of the components tray to create a new or local collection. Open that location in the secondary pane, drag and drop from the upper pane. Also, you can create the folder structure in the file manager, I don’t speak Mac, and point out the component location to SU.
Thanks for your reply. I have tried that…. It works, but on a Mac it is hard to manage especially across multiple projects etc. But don’t you think it would be nice if there were folders like they have for layers oops ‘tags’ window? It would be so easy and so intuitive - so Sketchup like……
Cheers
