Floor plans
I’m trying to finish my floor plans on the go with a chrome book but can’t get into 2D to do so any tricks to getting it to work
You will at some point want to get used to working in 3D, even on things that are flat on the ground. But, to get you into a 2D like view, click on the clapperboard icon on the right, then on the middle of the nine house buttons (to get a top down view), and also click on the parallel projection button in the upper left of that panel.
@ezraram, then save this scene to always instantly return to this TOP view in ‘Parallel Projection’
(you may even want to change settings in the same 'Scenes window: Settings > set Transition time to zero)
Panning will keep you in Top view. Orbitting will change the view to a different angle.
