If you flip it over and try to select the area around the other “8”, it’s divided into four oddly shaped areas. I’ve tried everything I can think of, and I cannot merge the four areas into one flat surface.
The STL file format always consists of triangles. When you import it into SketchUp and the feature is enabled, SketchUp tries to remove the triangulation, but the process is not always perfect.
On thing to note is that the divided face isn’t vertical. Here I’ve scaled the model up by 1000 to make it more evident. Note the Y-values. They all ought to be 0.000000.
Wow, you are way faster at this than I am. Thanks!
I see what you mean about the Y-values. Is there a way to fix this? That is, some way to move the point along the Y-axis only until it snaps to the surface? Or perhaps manually specify the Y-value for a given point?
You can move endpoints but there are a lot of them in your model to move. Seems to me that modeling the thing correctly is a better investment of your time than trying to fix something someone else screwed up.
You can move each point to a specific coordinate if you want. In this case, assuming that you want all the X and Z values to remain the same and set only Y to zero, you can start the move and then type [,0,] The square brackets indicate these are absolute coordinates and by not typing the X and Z values, they remain unchanged. Of course do you even know if the X and Z values are correct?
