File size - errors with layout
Hi, I’m using Sketchup and Layout 2020. The file size I’m currently working on is 160000KB in SketchUp and it’s having trouble sending and opening up in Layout. Is there a way to make it a more manageable file?
I think the file size must be the cause of the issues I’m having as smaller files are working fine.
The first thing I would do in SketchUp is go to Window>Model Info>Statistics and click Purge Unused. Does that reduce the file size?
Thank you - have done - will see if I can work with that now thanks.
