Hello, im having problems opening my file, its version SketchUp 2023, can anyone please please help. i also do not have the skb file. only skp, bellow is the file attached
@colin can you please help?
@DaveR can you please help?
Nearly half of the file you shared is nothing but zeroes. Nothing to recover from it.
Where were you saving the file while you worked on it.
Are you using a cr acked version of SketchUp 2023?
Did you have any power failure events while working on the file?
I still need help please
I saved on d on my computer
Not cracked
And also there was a power cut but after it was saved not before
There’s nothing to be done with the existing file. You’ll have to start over.
(You edited your previous post after I posted the following.)
Why don’t you have a .skb file?
Where were you saving the file while working on it?
Are you using a cr acked version of SketchUp? There is no “SketchUp for Schools” 2023. SketchUp for Schools is a web-based version for school children.
I cannot find the skb file i don’t know how its saved, this pc is not mine so not my sketchup im only working on it and i asked and they said its licensed
If SketchUp was set to create a backup the .skb file would be in the same directory as the .skp file.
You should check to see how it is licensed. If it has a “Classic” license added it would be cr acked and that could be related to this issue.
Wait! First it’s your computer and then it’s not.
No matter what, at this point starting over is the only option for you.
FWIW, I would suggest that you get your own legitimate subscription license for SketchUp and use it. Then, as you are working on your models save them on the internal drive and save a backup to Trimble Connect. Install the current version of SketchUp, too.
I remove it
hi,no need to multipost, leave us time to come around and do our job…
especially under a different account
Why are you posting the same file as two different users in two different threads?
SORRY, I use notebook created model and my partner helped at His PC.
Are you augustsome?
nevemind I created New better yet,
