I worked just fine with my model until I repositioned it, then some weird stuff started to happen and I don’t know how to make it work back again, unless I undo the repositioning (which I would not like).
I rotated my model about 45 degrees to make it compatible with sun orientation and check for shadows, also to make it in position with satelite image (not big deal but nice to help me).
I also raised the model height to try to make it in a sloped terraing like in real life, but I don’t know if I made it the correct way.
I also tried to reposition the axis at the model level and model orientation, but did not solved all the problems.
The problems that arise from this:
When I will use some tool that need Y axis (blue), then it orient to the original position (zero degrees north), I have to move the mouse pointer around to make it orient the way I want (it flicks between the two orientation: zero and 45 degrees). This is commonly seen with the Retangle tool.
Protactor and Rotate tools ALWAYS start from the original orientation of zero degrees north. Even with Axis repositioned.
Section Plane tool also start oriented to original zero degrees north and I can’t rotate it. Like Protactor and Rotate, I can still use it but it is annoying to see it in the wrong orientation of the model AND I am afraid this can cause me troubles in the future, once I use more advanced features in Sketchup or perhaps Layout.
Finally my eye level is not correct. I input 1,70 (one meter and 70 centimeters) and SU always throw me above my ceiling which is much more then 3 meters high. Again I tried to re-position the AXIS tool to make zero heigh the level of my model, but look like it is not working.
Can you help me with that?
Thanks a lot.
Casa Av Parque 3 eletrica.skp (3.6 MB)
