I start from the shape, pushpull it to make a broad wing. at this point, I softened it to get rid of the line, or if I had been smarter, I could have selected the contour BEFORE pushpull and weld it.
itâs late, Iâm not smart anymore.
when you select the wing, if you select ALL of it, you see it scales globally. not good.
but if, as dave said, you select only the top face, then it will deform.
deforming while pressing shift or ctrl will give you various solutions. here I pressed shift to have an uniform deformation, and deformed it only in one direction.
Ok, as I was typing I saw you managed to do it. so here is for the next one to have issues making a wing
yeah, neither have I. my âwatch laterâ pile is almost as long as my âto read somedayâ one
time to 3d print these for a high powered rocket. Going to add some fun electronics to the rocket for a competition for active drag systems and stability.
I have my level 2 certification and now working on level 3 haha.
if you want to make the wing hollow, say to save weight, printing time, pass some cables etc⌠you can either âdrillâ holes after (for cables) or you can make it hollow in 2d, before all the steps.
yup, same here. I have been doing so many research papers and thesis stuff for my end of degree in aerospace and biomed that i have hardly anytime to do anything. I used to be really good at SU because dave taught me alot of it and many others on these forums. I am going to start recording things i make so i can remember how to do it hahaha.
