Extruded Face of a Profile - Unwanted artifact, how to get rid of it?
Attached is an image of a raised flowerbed. I created it by drawing the outside edge of the bed on the green face. I then created the profile of the grade at the top right corner of that edge. I used the outsde flower bed edge as the edge for that face to follow using the follow-me tool. This was the result.
It’s OK except for:
  1. there is some artifact present on the arced face along the top curve. I’m not sure what is causing it. If I erase the lines, the face of the profile starts to disappear.
I’m guessing it may be some unwanted remnant from when I was experimenting on how to create this bed.
That’s not uncommon when the width of the profile is greated than the radius of the curve in the path. You can get araound that by drawing the path on the inside of the profile instead.
fm
It looks like the cirves at the corners of the path aren’t tangent with the edge between them. Is that what you want? Do you intend to fill the inner part with a surface?
If you must use the path on the outside as you’ve done, you can clean up the extrusion by first selecting all of the geometry and using Intersect Faces>With Selection. Then you can erase what you don’t want.
Cut it in half (solid tools or by intersecting faces). Mirror the good half over and solid tools union or combine the geometry.
Thank you, it took me a bit, but I resolved the issue. I had some dirty non tangent connections that I think contributed to the issue. Once I cleaned them up, I followed using the outside line and it seemed to have resoved itself.
