Hey,
I’ve been looking for a long time for a smooth way to extrude surfaces along a rotating path. For example, a staircase.
For a project I have to extrude a banister along a rotating staircase but I can’t do this at all. I’m using 1001bit - tools (extrude selected profile along selected path) but it doesn’t work.
Can someone help me?
Try Eneroth Upright Extruder extension, or Follow Me tool.
I have already tried but it does not give the desired result.
Because it has a rotating path.test.skp (228.8 KB)
Profile builder is very good. Profile Builder - mind.sight.studios
TutorialsUp recently did a series of videos on it, here’s the 1st:
How to Use Profile Builder Plugin For SketchUp | Part 1 - Profile Dialog - YouTube
Hi, I’ve also tried profile builder, but I don’t get the desired result.
The red one test(SU2017).skp (514.9 KB)
There are also hidden lines and faces on the original path.
hello, thank you, but may i ask how you did this?
I used CLF Perpendicular Face Tools and placed a few faces along the path, then I used Curviloft.
No railings on the left side of the stair? It wouldn’t meet the code in our parts. Unsafe at any speed.
