Extension issue Soap Skin & Bubble
I thought this would be a great way to make cushions so I installed Soap Skin & Bubble, selected my edges and applied the soap skin, adjusted the mesh, clicked on Generate Bubble and this warning comes up, even though the geometry is clearly selected. When I click okay it just becomes a blank grouped geometry.
It did sort of work once but I had to put in outrageous numbers for pressure to make it do anything.
I tried disabling and reinstalling … shut down computer overnight, tried again today, fresh file, no luck.
Any ideas on this one?
Is what you are selecting a group?
Share the .skp file so we can see exactly what you’ve got.
Soap Bubble Test.skp (2.0 MB)
Here you go
Should I group it first?
Never mind I just tried that, making it a group first and got the same result.
I suspect you were selecting the group made by the extension along with the original edges.
Leave the original edges ungrouped. Select them and start SSB. Enter the number of subdiviisions and press Enter. Then, to give it some bulginess, use the other tools with just the group created by SSB selected. In this case I selected the third button on the toolbar and entered -100 to get the bulge here.
ssb
ssb
When the edges you begin with are coplanar, SB&B will just create a flat plane. It’s expected behaviour..
Literally did exactly that and I get the pop up telling me I must select a group made in Soap Skin.
Is it some sort of graphics card setting?
As I wrote, you probably also selected the edges underneath the group.
When I click on Generate Soap Bubble I get that pop up, I can make the mesh and set the parameters but as soon as I as it to generate a bubble it gives me the warning
Are you pressing Enter after activating the tool and setting the number of divisions? It’s actually pressing Enter for the number of divisions and Enter again to complete.
So press enter twice?
Yes. Once to enter the number of divisions and then again to actually make SSB do its thing.
THANK YOU!! Press enter to set the number and press enter again to enter pressure. I am gobsmacked :slight_smile: I really appreciate the help!
Keep in mind the sign when you add the pressure. Since the back faces are up, positive pressue will bow the surface downward and negative will go up. At some point you should correct the face oirentation so you don’t have exposed back faces.
Yes thanks, I am just thrilled it did something i could get it to work at all!
Just trying to get some softness to my seat cushion. Not perfect yet but a good learning moment.
