Exporting to DWG, creating blocks from components
Hi!
I have a large model in SU and I want to export it to dwg. However, when I do so, the components freaks out transforming into blocks. One component will be one separate block - but also included in totally different block. Adjusting this component and exporting again will cause the same problem, but with a totally different component.
Anyone else experience this? What do I do?
BR/ annelid
…my only solution so far is to explode the entire model and exporting - but the file size is huge :frowning:
Any way you can show us what is happening? SketchUp does not have entities called “blocks” so I am a little confused as to what is happening…
Can you share a portion of your model, that results in the same type of export issue, so we can have a look?
CD
