Export to Solidworks
I need to export SketchUp Pro 2023 to Solidworks. Is a plug-in required for this or can it be done in Sketchup?
I ultimately need a ‘Stepfile’ file for a laser cutter for the manufacture of a steel staircase if that helps.
If you need to export your 3D model you could try exporting as a 3D DWG and import into Solidworks that way.
Or try exporting as an STL - I think Solidworks can import that,
But if your manufacturer just needs a flat blank profile to lasercut then you could send your part to layout, create a drawing and export that as a DXF or DWG.
Thank you.
An IFC file is basically the same as an STEP file, you might try that.
Either way, it is not gonna be a Solidworks solid, just a messh
